WIFI / Bluetooth Interface ​
Rhino Pi X1
  • WIFI: Supports Wi-Fi 7 (802.11be), 2.4G / 5G / 6G Hz DBS, 2*2 MIMO
  • Bluetooth: Supports BT 5.3
The antenna interface uses an IPEX Gen 4 connector. To use the WIFI / BT functions, two antennas need to be installed to enhance the WIFI / BT transmit power and receive sensitivity.
Hardware Connection ​
Install the antennas to the antenna interfaces of the Rhino Pi X1.
Tip
You can refer to the Hardware Information tutorial to locate the corresponding hardware interfaces.
Recommended antenna: AIWF022 antenna
Purchase link: AIWF022 Antenna WIFI7 Built-in FPC Antenna 2.4G & 5.8G Dual-band PCB Flexible Antenna ZigB - Taobao
WIFI Usage ​
Tip
All the following tests are performed in AidLux. Please refer to the AidLux / Ubuntu System - Quick Start - Browser Login section to log in to the system.
After installing the antennas, open the AidLux Web desktop, click Settings - Wireless Settings, and connect to a wireless WIFI network. After connection, you can check the WIFI signal strength using the following command:
iw dev wlan0 link
The command output is as follows:
Connected to 62:65:b2:8e:53:29 (on wlan0)
        SSID: TestGroup_5G
        freq: 5180
        RX: 10064 bytes (31 packets)
        TX: 8704 bytes (50 packets)
        signal: -46 dBm
        rx bitrate: 309.7 MBit/s 40MHz HE-MCS 6 HE-NSS 2 HE-GI 0 HE-DCM 0
        tx bitrate: 206.4 MBit/s 40MHz HE-MCS 4 HE-NSS 2 HE-GI 0 HE-DCM 0
Bluetooth Usage ​
Bluetooth Connection on the Integrated System ​
For the Bluetooth connection of the Rhino Pi X1 integrated system, you only need to connect on the Android side. The connection method is as follows:
  • Open the Android home screen, press and hold the left mouse button and slide upward on the screen, then find the Settings option on the page that appears.
  • Click Settings - Connected devices - Pair new device to scan and connect Bluetooth devices.
Bluetooth Connection on Ubuntu ​
The connection method for the Rhino Pi X1 Ubuntu system is as follows:
  • Connect an HDMI display and log in to the GNOME desktop.
  • Click Settings - Bluetooth to open the Bluetooth settings and connect.
