Board Introduction ​
The debug baseboard (model: A8625MY1-SUB-REVA) is a companion development baseboard designed specifically for the Rhino Boost Q86. It breaks out all Mini PCIe edge-connector interfaces into standardized debug interfaces and provides a complete power solution, making it suitable for rapid prototyping and function validation.
Debug Baseboard
Product Specifications ​
Specification ItemDescription
Compatible compute cardRhino Boost Q86 (Mini PCIe interface)
Power supply12V DC jack (J4) or 12V Type-C (requires soldering a 22.6K resistor)
Debug serial portType-C (J7), breaks out Rhino Boost Q86 UART, baud rate 115200
Network interfaceRJ45 (J8), breaks out 2.5G Ethernet
USB expansionUSB-A interface (J5), supports camera, USB drive, and more
Fan interface5V fan driver header, supports active cooling
5V outputJ3, can power host boards such as Raspberry Pi
Interface Description ​
  • On-board interface table:
InterfaceSilk LabelFunction Description
DC power jackJ412V power input
Type-C powerJ1012V Type-C input (resistor required)
Debug serialJ7DEBUG/USB-C, UART breakout
EthernetJ8RJ45, 2.5G Ethernet breakout
USB-AJ5Peripheral interface (camera/USB drive, etc.)
5V outputJ3Can power host boards
Mini PCIe slot-Connects Rhino Boost Q86 compute card
Fan interface-5V fan drive
DIP Switch Description ​
A DIP switch (or FORCE_USB_BOOT jumper cap) is provided on the baseboard for entering flashing mode:
PositionStateFunction
Normal positionDefaultNormal boot and run
Force download positionConnected to 1.8VEnter EDL (9008) flashing mode
Power off the device before operating the DIP switch to avoid hot-plug damage.
