MIPI CSI Interface ​
The Rhino Pi-A1 enables D-PHY camera connection through the MIPI data interface. The specific interface pin definitions and supported cameras are described in the following sections.
D-PHY Camera IMX577 ​
Interface Pin Definition ​
Interface No.Signal DefinitionFunction Description
1GNDGround
2MDN0D-PHY lane 0 negative
3MDP0D-PHY lane 0 positive
4GNDGround
5MDN1D-PHY lane 1 negative
6MDP1D-PHY lane 1 positive
7GNDGround
8MCND-PHY CLK negative
9MCPD-PHY CLK positive
10GNDGround
11MDN2D-PHY lane 2 negative
12MDP2D-PHY lane 2 positive
13GNDGround
14MDN3D-PHY lane 3 negative
15MDP3D-PHY lane 3 positive
16GNDGround
17PWDNShutdown signal
18MCLKMaster clock
19GNDGround
20SCL3.3V I²C clock
21SDA3.3V I²C data
22VCC3.3V power
Supported Cameras ​
IMX577 module
Hardware Connection ​
Connect the MIPI camera module to the MIPI CSI interface of the Rhino Pi-A1.
You can refer to the Hardware Information tutorial to locate the corresponding hardware interface.
