Hardware Information
This page summarizes the core hardware composition and parameters of the Rhino Pi IQ9N (Rhino Pi IQ9N) for quick reference during development.
System Composition
The complete system consists of the CPU module, MCU, USB 3.0 HUB chip, USB 2.0 HUB chip, UFS storage, Wi-Fi/Bluetooth combo module, backlight chip, audio circuit, EPD to HDMI chip, power conversion chip, and other peripheral circuits.
CPU Module
The CPU module uses QCS9075M, which includes the IQ9075 CPU.
| Item | Parameter |
| CPU | Octa-core Kryo Gen 6 (Octa-core @ 2.36 GHz), up to 227 K DMIPS |
| GPU | Adreno 663 @ 800 MHz |
| NPU | 100 TOPS |
| Memory | 36GB LPDDR5 + 128GB UFS 3.1 |
| RTSS | Quad Cortex-R52 |
Peripheral Components
| Component | Specification |
| USB 3.0 HUB | 4-port USB SuperSpeed HUB controller integrating a 4-port USB HUB and USB PD functions, with 5 sets of SS PHY, 5 sets of USB 2.0 PHY, and 2 sets of PD PHY built in |
| USB 2.0 HUB | 4-port USB HUB controller; the upstream port supports high speed and full speed, and downstream ports support 480 Mbps / 12 Mbps / 1.5 Mbps |
| USB 3.0 to SATA | USB 3.0 (5 Gbps) ↔ 2 x SATA 3.0 (6 Gbps), supports UASP/BOT/LBA48 |
| Wi-Fi & BT | Wi-Fi 6 (802.11a/b/g/n/ac/ax) + Bluetooth 5.3, 2.4G/5G dual-band, up to 1200 Mbps |
| MCU | Qingke RISC-V2A core industrial-grade microcontroller, 48 MHz main frequency, supports 2 watchdog timers (independent and window type) |
| DP to HDMI | Converts a Type-C/DP source device to an HDMI/DP display device, integrating PD fast charging and an audio channel, up to 8K@30Hz / 4K@144Hz |
| Audio module | 4/6 MIC, wake-up, beamforming noise reduction, echo cancellation, directional pickup, VOIP call noise reduction, supports 5m long-distance pickup |
| PHY | Supports 10BASE-Te / 100BASE-TX / 1000BASE-T / 2.5GBASE-T, compatible with IEEE 802.3 and NBASE-T PHY, communicates with the MAC via SGMII |
Technical Specifications
For the complete product specifications, see Rhino Pi IQ9N Product Specifications.
Viewing Hardware Information
View CPU information:
cat /proc/cpuinfoView the kernel version:
uname -aView the system version:
cat /etc/os-release
cat /etc/version/etc/version returns the device firmware version number, which can be read from a computer with adb shell cat /etc/version.
View the temperature sensors:
cat /sys/class/thermal/thermal_zone*/tempThe returned value is in millidegrees Celsius, for example 51000 means 51 ℃.
View detailed hardware information:
sudo lshw
