Firmware Flashing ​
Reminder
Flashing will format the system. Back up your data in advance.
Flashing Tool Installation ​
Before using Rhino Boost Q86, developers need to preinstall required software on a local Windows PC:
  • USB driver: USB_Driver_qud.win.1.1_installer_10061.1.zip
  • System flashing tool: QPST_2.7.496.zip
  • ADB tools: platform-tools.zip
Software download link: Software Tool Package Download Link
USB Driver Installation ​
  • Extract USB_Driver_qud.win.1.1_installer_10061.1.zip.
  • After extraction, double-click setup.exe. When the Qualcomm USB Drivers installer appears, click next as prompted.
System Flashing Tool Installation ​
  • Extract QPST_2.7.496.zip to the current folder.
  • Enter the extracted QPST_2.7.496 directory, then double-click QPST.2.7.496.1.exe to install.
  • Follow the prompts and keep clicking next to complete installation.
  • You can enter this directory and send QFIL.exe to the desktop.
  • Desktop icon shown below.
ADB Tool Installation ​
  1. Extract
  • Extract platform-tools.zip to drive D.
  1. Configure ADB environment variables
  • Copy the extracted platform-tools path.
  • Right-click "This PC - Properties".
  • In the settings window, click "Advanced system settings".
  • In the System Properties window under Advanced, click "Environment Variables".
  • In the Environment Variables window, select Path under "System variables" and click "Edit".
  • In the Edit environment variable window, click "New" and add the platform-tools path copied above.
  • Click "OK" to save and exit.
  1. Verify ADB environment
  • Open a cmd window, run adb, and ensure no error is reported.
Ubuntu System Installation ​
Switch to Flash Mode ​
  • After the device boots, connect the PC and device with a USB Type-A to Type-C cable. Type-A connects to the PC USB port, and Type-C connects to the device.
  • After connection, press WIN+R on Windows, enter cmd, and run adb devices in the opened window. Connected devices will be listed. If not shown, wait a while, or replug the Type-C cable and run the command again.
  • Switch to flash mode by running adb root;adb reboot edl.
adb root
adb reboot edl
  • If using the debug baseboard in kit mode, the board has a built-in DIP switch to force flash mode, as shown below:
Set the device DIP switch to force flashing mode and power-cycle (using the power switch or unplug/replug power cable). If port 9008 is detected, setup is successful.
Configure QFIL Configuration Item ​
  • Open QFIL and click Configuration - FireHose Configuration.
  • In the Download Configuration window, set the following:
Set Download Protocol to 0-Sahara
Set Device Type to ufs
Enable Reset After Download
Keep other options consistent with the screenshot below.
  • After configuration, click OK to save.
Select Flash Port ​
  • Click Select Port, then in the popup select port 9008 and click OK.
  • After switching via the Switch to Flash Mode section, this window should show port 9008 automatically. If it does not appear, power-cycle and switch again, then wait for it to appear.
Select Build Type ​
  • Find Select Build Type and choose Flat Build.
Select Flash Files ​
  • Extract the ROM package. The example below uses version A8625MY1-ubuntu_7DE921EA6.25_U06_260410.
  • Find Select Programmer, click Browse... after Programmer Path, and select files in the extracted ROM path.
  • Change the file type filter to All Files (*.*).
  • Select xbl_s_devprg_ns.melf, then click Open.
Select Flash XML Files ​
  • Find Select Flat Build, click Load XML..., and select flash XML files.
  • In the popup, select all files and click Open.
  • Another popup appears automatically. Select all files and click Open.
Start Flashing ​
  • After all options are selected, click Download to start flashing.
  • Wait about 5 minutes. When successful appears, flashing is complete. If flashing fails, contact APLUX after-sales support.
  • After flashing, the system reboots automatically.
Warning
If you entered 9008 flashing mode using the debug baseboard DIP switch, power off the device after successful flashing, switch the force-flash toggle back to the opposite direction, then power on again.
