Display Porting
This document describes the MIPI panel porting process, including device tree configuration and panel driver adaptation based on the DRM framework (using the Yousee YX80040ACT as an example).
Device Tree Configuration
Configuration file:
text
layers/meta-qcom-hwe/recipes-kernel/linux/linux-qcom-custom/kernel-source/arch/arm64/boot/dts/qcom/qcm6490-idp.dtsdts
&mdss_dsi { // Qualcomm DSI node
vdda-supply = <&vreg_l6b_1p2>; // DSI power
status = "okay";
panel@0 { // LCD panel node
compatible = "yousee,yx80040act"; // LCD driver
reg = <0>;
/* 3.3V panel power */
power-gpios = <&tlmm 9 GPIO_ACTIVE_HIGH>; // LCD power gpio
/* Reset pin */
reset-gpios = <&tlmm 8 GPIO_ACTIVE_LOW>; // LCD reset gpio
backlight = <&pm8350c_pwm_backlight>; // Backlight PWM
port { // DSI port
panel0_in: endpoint {
remote-endpoint = <&mdss_dsi0_out>;
};Adding the Panel Driver
Kernel Configuration
Add the driver config in the following configuration file:
text
layers/meta-qcom-hwe/recipes-kernel/linux/linux-qcom-custom/kernel-source/arch/arm64/configs/qcom_addons.configkconfig
CONFIG_DRM_PANEL_YOUSEE_YX80040ACT=mKconfig
text
layers/meta-qcom-hwe/recipes-kernel/linux/linux-qcom-custom/kernel-source/drivers/gpu/drm/panel/Kconfigkconfig
config DRM_PANEL_YOUSEE_YX80040ACT
tristate "Yousee YX80040ACT panel driver"
depends on OF
depends on DRM_MIPI_DSI
depends on BACKLIGHT_CLASS_DEVICE
help
Say Y here if you want to enable support for the Yousee
YX80040ACT controller for 1200x1920 MIPI LCD panelsMakefile
text
layers/meta-qcom-hwe/recipes-kernel/linux/linux-qcom-custom/kernel-source/drivers/gpu/drm/panel/Makefilemakefile
obj-$(CONFIG_DRM_PANEL_YOUSEE_YX80040ACT) += panel-yousee-yx80040act.oPanel Driver Implementation
Panel driver based on the DRM framework:
text
layers/meta-qcom-hwe/recipes-kernel/linux/linux-qcom-custom/kernel-source/drivers/gpu/drm/panel/panel-yousee-yx80040act.c
