移植-显示
本文档介绍 MIPI 屏的移植流程,包括设备树配置与基于 DRM 框架的 Panel 驱动适配(以 Yousee YX80040ACT 为例)。
设备树配置
配置文件:
text
layers/meta-qcom-hwe/recipes-kernel/linux/linux-qcom-custom/kernel-source/arch/arm64/boot/dts/qcom/qcm6490-idp.dtsdts
&mdss_dsi { // 高通 DSI 节点
vdda-supply = <&vreg_l6b_1p2>; // DSI power
status = "okay";
panel@0 { // LCD panel 节点
compatible = "yousee,yx80040act"; // LCD driver
reg = <0>;
/* 3.3V panel power */
power-gpios = <&tlmm 9 GPIO_ACTIVE_HIGH>; // LCD power gpio
/* Reset pin */
reset-gpios = <&tlmm 8 GPIO_ACTIVE_LOW>; // LCD reset gpio
backlight = <&pm8350c_pwm_backlight>; // 背光 PWM
port { // DSI port
panel0_in: endpoint {
remote-endpoint = <&mdss_dsi0_out>;
};添加 Panel 驱动
内核配置
在以下配置文件中添加 driver 的 config:
text
layers/meta-qcom-hwe/recipes-kernel/linux/linux-qcom-custom/kernel-source/arch/arm64/configs/qcom_addons.configkconfig
CONFIG_DRM_PANEL_YOUSEE_YX80040ACT=mKconfig
text
layers/meta-qcom-hwe/recipes-kernel/linux/linux-qcom-custom/kernel-source/drivers/gpu/drm/panel/Kconfigkconfig
config DRM_PANEL_YOUSEE_YX80040ACT
tristate "Yousee YX80040ACT panel driver"
depends on OF
depends on DRM_MIPI_DSI
depends on BACKLIGHT_CLASS_DEVICE
help
Say Y here if you want to enable support for the Yousee
YX80040ACT controller for 1200x1920 MIPI LCD panelsMakefile
text
layers/meta-qcom-hwe/recipes-kernel/linux/linux-qcom-custom/kernel-source/drivers/gpu/drm/panel/Makefilemakefile
obj-$(CONFIG_DRM_PANEL_YOUSEE_YX80040ACT) += panel-yousee-yx80040act.oPanel 驱动实现
基于 DRM 框架的 Panel Driver:
text
layers/meta-qcom-hwe/recipes-kernel/linux/linux-qcom-custom/kernel-source/drivers/gpu/drm/panel/panel-yousee-yx80040act.c
