Power Interface ​
The Rhino Pi-A1 supports DC wide voltage input, either 12V or 24V. The power supply is recommended to be no less than 36W.
DC round-hole power cable 12V 3A [DC5.5×2.5mm]
Power Interface
Hardware Connection ​
Use the round-hole power adapter cable shipped with the device to connect the DC12V/24V 3A power adapter to the power interface of the motherboard.
Normal Startup ​
Depending on the flashed firmware, the indicator light states during board startup will differ. Refer to the following:
Integrated System (AidLux) Firmware ​
  • During boot: The power indicator stays solid blue.
Ubuntu System Firmware ​
  • During boot: One green indicator away from the power interface lights up and then blinks; after the system finishes loading, the second green indicator stays solid.
