NTP Configuration ​
NTP Introduction ​
NTP (Network Time Protocol) is used to synchronize the system clocks of multiple devices within a local network. Inconsistent device time can lead to issues such as confusing log timestamps, TLS certificate validation failures, and file timestamp errors.
Scope of Responsibility ​
RoleResponsible PartyDescription
NTP Server (time source)Customer environment administratorProvides standard time; outside the configuration scope of this document
NTP Client (smart camera / development board)This documentSynchronizes time from the customer's NTP Server
This document focuses on Client-side configuration. For the Server side, only technical requirements are listed for the customer's administrator reference, along with a configuration example (for reference only).
Components Involved ​
ComponentDescription
NTP ServerThe node providing the time source in the customer environment, running ntpd, chronyd, etc.
NTP ClientThe configuration target of this document, an Ubuntu development board using the built-in systemd-timesyncd
UDP 123 PortThe default NTP protocol port; the Server must listen on it and the firewall must allow it
systemd-timesyncdUbuntu's built-in lightweight SNTP client, used only for synchronization, not as a Server
Two Scenarios ​
ScenarioApplicable ConditionsDescription
Scenario 1: Public InternetThe development board can directly access the InternetUse public NTP servers, no customer cooperation required
Scenario 2: Intranet EnvironmentThe development board cannot access the Internet, only the LANRequires the customer to provide intranet NTP Server information
Requirements for the NTP Server Side ​
The following requirements are provided for the customer environment administrator to confirm or set up the NTP Server. Once these conditions are met, provide the necessary information to the Client configuration personnel of this document.
1. NTP Protocol Support (RFC 5905) ​
The Server must run a standard NTP daemon. The applicability of common solutions is as follows:
SolutionRepresentative SoftwareSuitable as Server
Classic NTPntpd✅ Full-featured, good compatibility
Modern lightweight NTPchronyd✅ Recommended, performs better in embedded / unstable network environments
System built-insystemd-timesyncd❌ Not recommended; it is itself an SNTP client with weak Server capability, unsuitable for multi-client scenarios
Conclusion: Deploy chronyd or ntpd as the Server. Do not use systemd-timesyncd as a Server.
2. Port Open (UDP 123) ​
NTP uses UDP default port 123. The Server side must:
  • Listen on UDP port 123
  • Allow inbound UDP 123 traffic through the firewall
3. Stable and Reliable Time Source ​
The Server's own time must be accurate. It is recommended to:
  • Connect upstream to a public NTP server (e.g., ntp.aliyun.com, ntp.ntsc.ac.cn) or a GPS time source
  • If the Server's own time is inaccurate, the time synchronized to the Client will also be wrong
4. Negotiation Mode ​
systemd-timesyncd (Client) queries using the standard client-server mode. The Server does not need to support broadcast, multicast, or symmetric key authentication (unless there are special security requirements).
Information the Customer Needs to Provide ​
Information ItemDescriptionExample
NTP Server IPThe Server's static IP address192.168.112.81
Port NumberDefault 123; specify if non-default123
Network ZoneConfirm the Client and Server are in the same LAN or a routable network—
Scenario 1: Public Internet Environment ​
When the device is connected to the Internet, systemd-timesyncd uses ntp.ubuntu.com as the time source by default, so no additional configuration is required — only verification.
Check Synchronization Status ​
Run on the Client:
timedatectl timesync-status
Check NTP Server ​
timedatectl show-timesync | grep Server
Check Synchronization Logs ​
sudo journalctl -u systemd-timesyncd --no-pager -n 10
Verification Criteria ​
Check ItemExpected Result
NTP Serverntp.ubuntu.com or a public address
Packet count> 0
Log keywordInitial synchronization to time server
Scenario 2: Intranet Environment ​
In an intranet environment, obtain the NTP Server information from the customer administrator, then configure the Client to point to that Server.
Prerequisite: Obtain NTP Server Information ​
Confirm the following information with the customer administrator (refer to "Information the Customer Needs to Provide" above):
  • NTP Server IP: e.g., 192.168.112.81
  • Port Number: default 123
Configure NTP Client ​
Step 1: Modify the Configuration File ​
Edit /etc/systemd/timesyncd.conf:
ini
[Time]
NTP=<NTP_Server_IP>
FallbackNTP=ntp.ubuntu.com
RootDistanceMaxSec=10
ParameterDescription
NTPThe NTP Server address provided by the customer
FallbackNTPOptional fallback public NTP; automatically switches when the Server is unavailable
RootDistanceMaxSecNTP root distance upper limit; must be set to 10s for Windows Server, can be omitted for Linux Server (default 5s)
⚠️ Note
If the NTP Server is Windows w32time, its root distance is about 8~10 seconds, exceeding the system default of 5 seconds. You must configure RootDistanceMaxSec=10, otherwise the connection will be rejected with the log message Server has too large root distance. Disconnecting. Linux chronyd/ntpd are not affected by this limitation.
Step 2: Restart the Service ​
sudo systemctl restart systemd-timesyncd
Verify NTP Configuration ​
Step 1: Confirm Network Connectivity ​
ping <NTP_Server_IP>
Step 2: Manually Query the NTP Server ​
sudo ntpdate -q <NTP_Server_IP>
It should normally return the Server's current time.
Step 3: Check Synchronization Status ​
ServerThe customer-provided NTP Server IP
Packet count> 0
Root distance...s (max: 10s)
Step 4: Check Synchronization Logs ​
sudo journalctl -u systemd-timesyncd --no-pager -n 5
Expected log output:
Initial synchronization to time server <NTP_Server_IP>:123 (<NTP_Server_IP>)
Step 5: Modify Time to Verify Synchronization ​
💡 Tip
This step is only for second-level offset testing. It is not recommended to set a large time difference.
# Record the current time
date "+%Y-%m-%d %H:%M:%S"
# Offset by 1 hour
sudo date -s "$(date -d '+1 hour' '+%Y-%m-%d %H:%M:%S')"
# Wait 10 seconds and check whether it recovers automatically
sleep 10
timedatectl timesync-status | grep -E "Packet|Offset"
⚠️ Note
systemd-timesyncd only automatically corrects second-level offsets. If the Client time differs too much from the Server (e.g., by days or years), the synchronization service will refuse to sync due to the security protection mechanism. In that case, manually run sudo ntpdate -s <Server IP> to recover.
Appendix: NTP Server Configuration Reference (For Reference Only) ​
The following Server-side configuration examples are outside the configuration responsibility scope of this document and are provided only for the customer environment administrator's reference.
Windows 11 Example (Using w32time) ​
Enable NTP Server ​
Open PowerShell as administrator and run the following commands in sequence:
powershell
# Enable NTP Server
Set-ItemProperty -Path "HKLM:\SYSTEM\CurrentControlSet\Services\W32Time\TimeProviders\NtpServer" -Name "Enabled" -Value 1
# Set as a reliable time source
Set-ItemProperty -Path "HKLM:\SYSTEM\CurrentControlSet\Services\W32Time\Config" -Name "AnnounceFlags" -Value 5
# Allow UDP 123 port through the firewall
New-NetFirewallRule -Name "NTP Server" -DisplayName "NTP Server (UDP 123)" -Protocol UDP -LocalPort 123 -Action Allow -Profile Any
# Restart the time service
Restart-Service w32time
Verify Server Status ​
powershell
# Ensure Windows' own time is accurate
w32tm /resync
# View configuration status
w32tm /query /configuration
alt textalt text
Linux Example (Ubuntu 24.04, Using chronyd) ​
Install chrony ​
sudo apt update && sudo apt install chrony -y
Configure NTP Server ​
Ubuntu 24.04 has upstream time sources configured by default. You only need to append two lines to the end of /etc/chrony/chrony.conf to enable the Server:
sudo tee -a /etc/chrony/chrony.conf << 'EOF'
allow 192.168.0.0/16
local stratum 10
EOF
allowAllow clients on the specified network segment to sync; must be configured, otherwise UDP 123 port is not listened on
local stratum 10Fallback time source when upstream is unreachable
Allow Through Firewall ​
sudo ufw allow 123/udp
Start the Service ​
sudo systemctl enable chrony
sudo systemctl restart chrony
# View time source synchronization status
chronyc sources -v
# View NTP service statistics
chronyc tracking
# Confirm UDP 123 port is listening
sudo ss -uln | grep 123
alt textalt text
Example expected output:
$ chronyc tracking
Reference ID    : 7F5D2E3C (ntp.aliyun.com)
Stratum         : 3
Ref time (UTC)  : Sun Aug  3 06:30:00 2026
System time     : 0.000012345 seconds slow of NTP time
Leap status     : Normal
Recommended solution: For Linux environments, it is recommended to use chronyd or ntpd, which offer more flexible configuration and better compatibility.
Notes ​
ItemDescription
NTP Server responsibilityThe Server side is maintained by the customer environment administrator; the Client side only needs its IP and port
RootDistanceMaxSecWhen connecting to Servers such as Windows w32time, must be set to ≥ 9s (10s recommended)
FirewallThe Server side must allow inbound UDP 123 traffic
Network typeWindows Server is recommended to be set to "Private network"
Large offset synchronizationWhen the time difference between Server and Client is too large, run sudo ntpdate -s to sync manually
Polling frequencyDynamically adaptive, initially 32 seconds, up to 34 minutes when stable
Troubleshooting ​
SymptomCauseSolution
Timed out waiting for replyNetwork unreachable or firewall blockingping the Server address, and check the port with nc -u -zv <IP> 123
too large root distance. DisconnectingRootDistanceMaxSec not configured or too smallSet to 10s and restart the service
Packet count: 0Service just started or Server unreachableWait 30 seconds and re-check; confirm the Server is online
Large offset time not recovered automaticallytimesyncd security protection triggeredRun sudo ntpdate -s <Server IP> to recover manually
no server suitable for synchronizationServer time abnormal or NTP service not startedConfirm the Server-side NTP daemon is running normally
