Hardware FAQ ​
Q1: No response after power-on ​
  • Check whether the power adapter meets 12V/3A (recommended).
  • Confirm power interface is connected correctly and plug is not loose.
  • If using Type-C power, confirm required resistor soldering is completed.
Q2: No serial output ​
  • Confirm you are using debug serial interface (J7) and the correct serial port.
  • Recommended serial parameters: 115200, 8N1.
  • Replace cable to exclude charge-only cable issues.
If the above issues cannot be resolved, please contact APLUX technical support at noah.yang@aidlux.com
