Rhino Pi X1R Carrier Board Introduction ​
Product Overview ​
The Rhino Pi X1R carrier board is compatible with both the Rhino Core Q85 and Rhino Core Q64 smart modules. The carrier board provides dual Gigabit RJ45 network ports, USB 3.0 Type-A and expansion USB 2.0 connectors, as well as display interfaces such as MIPI DSI/CSI, HDMI, and eDP. It also supports multiple general-purpose bus interfaces including SPI, I2C, RS485, UART, I2S, CAN, and GPIO.
An onboard WiFi 6 + BT 5.3 module, a standard Mini-PCIe interface for 4G communication expansion, a Micro SD card slot for external storage expansion, and audio input/output interfaces are also provided. The board is designed for high-compute and high-stability scenarios such as robotics, industrial AI, and high-end IPC/VR applications.
Product Appearance ​
Photo of the Rhino Pi X1R mainboard: Rhino Pi X1R carrier board
Interface Diagram ​
Rhino Pi X1R carrier board front interface diagram
Rhino Pi X1R carrier board back interface diagram
Physical Dimensions ​
ItemParameter
PCBA dimensions135mm × 90mm (±0.5mm)
Board thickness1.6mm (±10%)
Mounting hole diameter6mm
Screw hole specification∮3.2mm × 4 (±10%)
Overall dimensions (including components)135mm × 90mm × 14mm, PCB front height 9mm
For detailed dimension information, contact the APLUX FAE at noah.yang@aidlux.com.
Specification List ​
CategorySpecification
Core Board 1Rhino Core Q85 smart module (A8550MA1, optional)
Core Board 2Rhino Core Q64 smart module (A6490MA1, optional)
TF CardPush-push TF card socket, supports up to 256GB TF card
USB2 Type-A (USB 3.0 ×2), 4 built-in 1.25mm latching vertical connectors (USB 2.0 ×4), 4 2.0mm latching horizontal connectors (USB 2.0 ×4)
HDMIStandard HDMI display interface, supports 4K@60Hz output
LCD InterfaceIndustry-standard 30-pin eDP socket; 4-lane MIPI DSI display interface
TouchFPC interface, supports I2C touch
Camera2× MIPI CSI × 4-lane
I2S Interface1× I2S interface
Ethernet2× 10/100/1000M auto-negotiation Ethernet RJ45 ports
Mini-PCIeIndustry-standard m-PCIe 4G module interface
SIM CardPush-push Nano SIM card socket, supports mobile communication
CAN Bus2× CAN pin header interfaces, supports CAN 2.0B and CAN FD
CodecLow-power voice processing and audiophile-grade audio playback (supports 4 microphones)
Headphone/MicrophoneSupports US-standard 4-pole 3.5mm headset combo jack (left-right-ground-mic)
SPI Bus2 individual SPI pin header interfaces, 1 shared with I2C
GPIOSupports 10 external 1.8V GPIOs
Serial CommunicationSupports RS485/UART communication, 2× RS485, 6× UART
ButtonsFlashing button (RECOVERY) and power button
Power InputSupports 10~24V wide-voltage DC input (12V/3A recommended)
Debug InterfaceSupports external 3.3V serial debug
Line OutputSupports standard left/right channel line output (pin header interface + headphone interface)
WiFi / BluetoothOnboard WiFi 6 + BT 5.3
Environmental RequirementsOperating temperature -25°C ~ 50°C, storage temperature -40°C ~ 85°C, operating humidity 0%~95% (non-condensing)
Physical DimensionsL × W × H (135mm × 90mm × 14mm), PCB front height 9mm
Operating SystemRhino Core Q85 smart module: Ubuntu 22.04; Rhino Core Q64 smart module: Ubuntu 24.04
Functions and Interface Definitions ​
USB 2.0 Interfaces (J8 / J9 / J10 / J11) ​
usb2.0x4
J8, J9, J10, and J11 are USB 2.0 HOST interfaces, all routed through the PCIe-to-USB chip uPD720201K8. Each interface has an independent load switch with a load capability of 1.2A. The connector type is a 1×4×2.0mm latching connector, manufactured by TXGA, model FWF20029-S04B25NAM.
Pin Definitions:
Pin#DefinitionNote
15V5V output
2DMUSB differential data -
3DPUSB differential data +
4GNDDigital ground
USB 2.0 Interfaces (J12 / J13 / J14 / J15) ​
usb2.0x4
J12, J13, J14, and J15 are USB 2.0 HOST interfaces, all routed through the USB HUB chip FE1.1, so they share a 480Mbps bandwidth. J12 and J13 share one load switch, and J14 and J15 share another load switch, with a maximum load capability of 1.2A for the two USB interfaces. The connector type is a 1×4×1.25mm latching connector, manufactured by Xunpu, model WAFER-GH1.25-4PLB.
Pin Definitions:
Pin#DefinitionNote
15V5V output
4GNDDigital ground
eDP Socket (J18) ​
eDP socket
【J18】Standard eDP socket (1×30×0.5mm), supports the eDP v1.4 standard. The connector is a bottom-contact, front-flip FPC connector, manufactured by Xunpu, model FPC-05F-30PH20.
Pin Definitions:
Pin#DefinitionNote
1NCNC
2GNDDigital ground
3D1-Differential data signal
4D1+Differential data signal
5GNDDigital ground
6D0-Differential data signal
7D0+Differential data signal
8GNDDigital ground
9AUX+Differential auxiliary signal
10AUX-Differential auxiliary signal
11GNDDigital ground
12LCD_3V3LCD_3V3 power output
13LCD_3V3LCD_3V3 power output
14NCNC
15GNDDigital ground
16GNDDigital ground
17ETX_HPDDetection signal
18GNDDigital ground
19GNDDigital ground
20GNDDigital ground
21GNDDigital ground
22BL_ENEnable signal
23BL_PWMPWM control signal
24NCNC
25NCNC
26BL_12VBL_12V power output
27BL_12VBL_12V power output
28BL_12VBL_12V power output
29BL_12VBL_12V power output
30NCNC
Backlight Socket (J20) ​
Backlight socket 【J20】Backlight socket (1×6×2.0mm), provides 12V backlight power. It is recommended that backlight power exceeding 20W be supplied by a separate backlight power board (the 12V adapter supplies power directly; a 24V adapter requires adjustment of the onboard power). It supports PWM-controlled backlight and backlight on/off. The connector is manufactured by Bossie, model BX-PH2.0-6PWZ-R.
Pin Definitions:
Pin#DefinitionNote
1GNDDigital ground
2GNDDigital ground
3PWMPWM control signal
4BL_ON/OFFBacklight on/off signal
5BL_12V12V power output
6BL_12V12V power output
Camera Socket (J22 / J23) ​
Camera socket J22 and J23 are camera sockets with identical signal definitions. Both support MIPI 4-Lane CSI with a maximum of 2.5Gbps/lane. The connector type is a 1×22×0.5mm front-flip FPC connector, manufactured by Xunpu, model FPC-05F-22PH20.
Pin Definitions:
Pin#DefinitionNote
1GNDDigital ground
2LN0_MDifferential data signal
3LN0_PDifferential data signal
4GNDDigital ground
5LN1_MDifferential data signal
6LN1_PDifferential data signal
7GNDDigital ground
8CLK_MDifferential clock signal
9CLK_PDifferential clock signal
10GNDDigital ground
11LN2_MDifferential data signal
12LN2_PDifferential data signal
13GNDDigital ground
14LN3_MDifferential data signal
15LN3_PDifferential data signal
16GNDDigital ground
17RSTReset signal
18LEDLED signal
19GNDDigital ground
20SCLI2C bus clock signal
21SDAI2C bus data signal
22CAM_3V33.3V power output
CAN Socket (J27 / J28) ​
CAN socket J27 and J28 are CAN connectors with identical signal definitions. Both support CAN 2.0B and CAN FD. The connector type is 1×3×2.5mm, manufactured by TXGA, model FWF25029-S03S25W5M.
Pin Definitions:
Pin#DefinitionNote
1HData
2LData
3VSSCAN shield ground
RS485 Interfaces (J37 / J38) ​
RS485 interface 【J37】【J38】are RS485 interfaces (1×4×1.25mm) with identical signal definitions, both with onboard 120Ω termination resistors. The connector is manufactured by Xunpu, model WAFER-GH1.25-4PLB.
Signal Definitions:
Pin#DefinitionNote
1VCC3.3V power output
2BDifferential signal
3ADifferential signal
4VSSRS485 shield ground
MIPI DSI Interface (J55) ​
MIPI DSI interface
[J55] is a 4-lane DSI interface using a double-sided-contact, flip-type 31-pin FPC connector. Connector manufacturer: HRS, model: FH35C-31S-0.3SHW(50). Compatible panel: Shenzhen Yousee, model: YX80040ACT.
PIN Definition:
Pin#DefinitionNote
1LEDABacklight anode
2LEDABacklight anode
3LEDABacklight anode
4--
5--
6LEDKBacklight cathode
7LEDKBacklight cathode
8LEDKBacklight cathode
9GNDDigital ground
10GNDDigital ground
11LN2_PMIPI DSI data signal
12LN2_MMIPI DSI data signal
13GNDDigital ground
14LN1_PMIPI DSI data signal
15LN1_MMIPI DSI data signal
16GNDDigital ground
17CLK_PMIPI DSI clock signal
18CLK_MMIPI DSI clock signal
19GNDDigital ground
20LN0_PMIPI DSI data signal
21LN0_MMIPI DSI data signal
22GNDDigital ground
23LN3_PMIPI DSI data signal
24LN3_MMIPI DSI data signal
25GNDDigital ground
26--
27ResetDisplay reset signal
28--
29--
303V3_LCDLCD 3.3V power
313V3_LCDLCD 3.3V power
USB/PWM Interface (J53) ​
[J53] is a USB/PWM interface (1×4×1.25 mm), connector manufacturer: Xunpu, model: WAFER-GH1.25-4PLB.
Q85 Adaptation Notes
When used with the 8550 Core Board, this interface is a PWM output (PM8550 GPIO used as PWM); when used with the 6490 Core Board, it is USB 2.0 (directly from the Core Board SoC). This document follows the Q85 configuration and treats it as a PWM output interface.
PIN Definition:
Pin#DefinitionNote
15V5V output
4GNDDigital ground
UART Interfaces (J39 / J40 / J41 / J43 / J44 / J45) ​
UART interface [J39], [J40], [J41], [J43], [J44], and [J45] are UART interfaces (1×4×1.25 mm) with identical signal definitions. Connector manufacturer: Xunpu, model: WAFER-GH1.25-4PLB.
All of the above interfaces can be used as UART with the 8550 Core Board; with the 6490 Core Board, J44 and J45 can only be used as GPIO (3.3 V level), not as UART. This document follows the Q85 configuration.
PIN Definition:
Pin#DefinitionLevelNote
1VCC3.3V3.3V power output
2TX3.3VData transmit (TTL)
3RX3.3VData receive (TTL)
4GND0VDigital ground
Notes ​
Please pay attention to the following key points when assembling and using the Rhino Pi X1R carrier board:
  • Environmental requirements: Relative humidity 0~95% non-condensing, operating temperature -25°C ~ 50°C, storage temperature -40°C ~ 85°C.
  • ESD protection: ESD protection is required during assembly and transportation of the complete product.
  • Cables: The interface cables of this board should not be too long; otherwise, signal quality may be affected.
  • Mechanical stress: Do not twist or press the board during assembly to avoid deformation.
  • Short circuit prevention: Never allow a short circuit between the bare board and other peripherals.
  • LCD connection: When connecting an external eDP LCD, check whether the driving voltage and current meet the requirements, and pay attention to pin 1 orientation of the screen cable socket.
  • Backlight power supply: When connecting an external eDP LCD, check whether the backlight voltage and current meet the requirements. If the LCD backlight power exceeds 20W, it is recommended to use a separate power board for backlight power supply.
  • Peripheral IO level and current: When connecting external devices to the peripheral interfaces (USB, GPIO, serial ports, I2C, SPI, HDMI, etc.), check whether the IO level and current of the peripheral meet the requirements. When using the power pins on the mainboard connectors to power peripherals, the current of regular power pins must not exceed 100mA. When connecting a serial port to a peripheral, level matching is also required (1.8V level, 3.3V TTL level, and RS-485 level).
Document Information
  • Official product name: Rhino Pi X1R
  • Full product code: A8550PZ1-COM6490
  • Document version: V1.0
  • Release date: 2026-07-20
  • Classification: Public
  • Scope of application: Rhino Pi X1R mainboard and complete product integration projects based on this hardware platform
© 2026 APLUX Intelligent Technology Co., Ltd. No unauthorized copying, distribution, or use beyond the scope agreed in this document.
