SSH Login ​
Prerequisites ​
Developers need the following hardware and network environment:
  • Mainboard: Q86 core board + debug baseboard
  • Power: DC12V 3A power adapter
  • Debug cable: USB Type-A to Type-C cable (for initial debugging)
  • Network: Rhino Boost Q86 and the host PC are in the same LAN (via adapter board RJ45 or same-subnet router)
Raspberry Pi 5 AI Acceleration Solution
SSH Software Installation ​
On Windows, cmd or PowerShell is recommended. On Linux/macOS, use the built-in ssh command.
Verify SSH client availability:
ssh -V
If the terminal outputs an OpenSSH version (for example OpenSSH_for_Windows_9.5p2), SSH client is available.
SSH client version check
Boot the Board ​
  • DC jack power (recommended): connect a 12V/3A adapter to J4 on the baseboard.
  • Type-C power: if using 12V Type-C input, solder one 22.6K 0402 resistor at the corresponding board location (refer to adapter board hardware documentation), then connect to J10.
  • After power-on, the system starts automatically.
Get Device IP ​
For first-time use, log in through ADB first and check current device IP:
adb shell ip a
Record the IP on the service NIC (for example 192.168.100.3), referred to as <Q86_IP> below.
Access the System via SSH ​
Run on the host terminal:
ssh aidlux@<Q86_IP>
SSH first login prompt
At first login, confirm host fingerprint by entering yes and pressing Enter. Then input password aidlux.
Common SSH Commands ​
These commands are commonly used in remote operations and maintenance:
  1. ssh aidlux@<Q86_IP>
Purpose: log in to device shell for remote debugging.
ssh aidlux@<Q86_IP>
  1. Upload via scp
Purpose: upload host files to device, commonly scripts, models, or config files.
scp ./test.sh aidlux@<Q86_IP>:/tmp/test.sh
  1. Download via scp
Purpose: download logs or result files from device.
scp aidlux@<Q86_IP>:/var/log/syslog ./syslog
  1. ssh ... "command"
Purpose: execute a remote command once, suitable for automation scripts.
ssh aidlux@<Q86_IP> "uname -a"
Password
SSH username is aidlux, password is aidlux.
Recommendation
Run ping <Q86_IP> first to verify network reachability before SSH login and file transfer.
Use the System ​
After successful login, developers can configure the system, troubleshoot logs, and deploy applications through SSH.
