System FAQ ​
ADB and SSH ​
Q1: Device not recognized by adb devices ​
adb kill-server
adb start-server
  • Confirm device is powered on normally.
  • Replug USB data cable and replace cable if necessary.
Q2: SSH connection timeout ​
  • Run ping <Q86_IP> first to verify network reachability.
  • Verify login command: ssh aidlux@<Q86_IP>.
  • Confirm device and host are in the same subnet.
Drivers and Network ​
Q3: Driver installation failed (dpkg reports file not found) ​
  • Enter the directory containing the driver package before installation.
  • Use ls to verify package filename matches a8625-driver-ubuntu_*.deb.
Q4: Network configuration lost after reboot ​
  • ifconfig/ip route commands are usually temporary and may be lost after reboot.
  • Use system network management for persistent configuration.
If the above issues cannot be resolved, please contact APLUX technical support at noah.yang@aidlux.com
