Hardware Introduction ​
This solution is based on the CEK2601-Pi5A8625MY1 adapter board developed by Firefly Workshop, enabling seamless integration between Raspberry Pi 5 and the Rhino Boost Q86 compute card. It is the preferred approach for entry-level developers to quickly validate AI applications.
Introduction to Raspberry Pi 5 and Firefly Workshop Adapter Board (CEK2601-Pi5A8625MY1) ​
Solution Components ​
  • Host Board: Raspberry Pi 5 (8GB version recommended), with a standard PCIe 16PIN physical interface
  • Adapter Board: CEK2601-Pi5A8625MY1 (by Firefly Workshop)
  • Core Compute Unit: Rhino Boost Q86 (based on Qualcomm QCS8625 4nm chip, 60 TOPS INT8 NPU)
  • Required Accessories: 12V/3A DC power supply or 65W Type-C PD adapter, PWM cooling fan, USB-A to USB-C debug cable, PCIe 2.5G FPC cable (recommended, replaces Ethernet cable and improves communication stability), Gigabit Ethernet cable (optional)
  • Adapter Board Model: CEK2601-Pi5A8625MY1 Raspberry Pi 5 AI Acceleration Solution
Core Adapter Board Specifications ​
CategoryDetailed Parameters
Product PositioningDedicated peripheral adapter board connecting Raspberry Pi 5 and the Rhino Boost Q86 compute card
Core Interfaces12V/3A Type-C power input (J10), 5V/3A Type-C output (J3, powers Raspberry Pi), Rhino Boost Q86 debug Type-C (J7), USB peripheral Type-C (J5), PCIe to 2.5G RJ45 (J8), native 40PIN IO (J2), PWM fan header (J6)
Power Supply12V/3A DC input or 65W Type-C PD adapter
Operating Temperature0~50C
Board Dimensions85.5mm x 58.3mm
Core FunctionsPCIe-to-Ethernet communication, Raspberry Pi power supply, debug breakout, peripheral expansion, thermal control
