Hardware Connection Guide ​
Key Interface Pin Definitions ​
PCIe 16PIN Communication Interface (connected to Raspberry Pi) ​
Pin LabelSignal NameLevelDescription
1RESET3V3Compute card reset signal
2CLK_REQ3V3PCIe clock request
3WAKE3V3Wake signal
4PWR_EN3V3Power enable
5/8/11/14GND-Ground
6/7PCIE_TX_N/PCIE_TX_P-PCIe TX differential pair
9/10PCIE_RX_N/PCIE_RX_P-PCIe RX differential pair
12/13PCIE_CLK_N/PCIE_CLK_P-PCIe clock differential pair
15/165V5VPower input
Native 40PIN IO Interface (J2, connected to Raspberry Pi) ​
  • Standard 2.54mm pitch 40PIN header, compatible with Raspberry Pi GPIO definitions
  • Occupied pins:
    • Pin 27 and 28: internally connected to E2PROM on the adapter board, unavailable for reuse
    • Pin 33 and 35: internally connected to Rhino Boost Q86 cooling fan control on the adapter board, unavailable for reuse
  • Remaining pins are available for peripheral expansion. For full pin definitions, see Section 7.6 of the Rhino Boost Q86 Compute Card Adapter Board Hardware Specification.
Other Key Interfaces ​
Interface IDInterface NameFunction
J10Type-C power input12V/3A input, powers the entire system
J3Type-C power output5V/3A output, powers Raspberry Pi 5 mainboard
J7Type-C debug interfaceBreaks out Rhino Boost Q86 UART debug serial for system log viewing
J5Type-C USB peripheralExtends USB devices on Rhino Boost Q86 compute card (for example USB drive, camera)
J6PWM fan headerRaspberry Pi outputs PWM signal to control Rhino Boost Q86 cooling fan
J8PCIe to RJ452.5G Ethernet interface for communication with Rhino Boost Q86 compute card
Mechanical Connection and Cabling Steps ​
General notes: All connection operations must be done with power off. Discharge static electricity before operation to avoid damaging electronic components.
FPC cable usage notes:
Hold the connector when plugging/unplugging the FPC cable. Do not pull on the cable itself to avoid internal wire breakage.
Avoid excessive bending during installation. The bend radius should not be less than 5mm.
Make sure both ends are fully inserted and latched to prevent poor contact and communication interruptions.
IMG_256
  1. Stack-install the adapter board: Align and insert the 40PIN header of CEK2601-Pi5A8625MY1 into the 40PIN GPIO on Raspberry Pi 5. Insert the adapter board PCIe 16PIN connector into the Raspberry Pi PCIe slot and ensure good contact.
  2. Install the Rhino Boost Q86 compute card: Connect Rhino Boost Q86 to J8 on the adapter board via PCIe 16PIN interface, then secure the compute card and adapter board with screws.
  3. Connect cooling fan: Connect the Rhino Boost Q86 PWM fan to interface J6 on the adapter board.
  4. Power connection: Connect a 12V/3A adapter to J10 on the adapter board, and connect J3 on the adapter board to the Raspberry Pi 5 power port with a Type-C cable.
  5. Compute card communication connection (choose one, FPC cable recommended first):
    • Recommended: PCIe FPC cable connection: Connect one end of the FPC cable to J8 on the adapter board (PCIe to RJ45) and the other end to the Ethernet port of Rhino Boost Q86. Compared with Ethernet cables, FPC cables provide more stable transmission and lower latency, effectively reducing packet loss during high-bandwidth AI data transfer.
    • Recommended purchase link: https://item.taobao.com/item.htm?id=862597845004 (if unavailable, search for "Raspberry Pi 5 A8625 PCIe 2.5G FPC cable").
    • Alternative: Gigabit Ethernet cable connection: Use a standard Gigabit Ethernet cable between J8 on the adapter board and the Rhino Boost Q86 compute card Ethernet port, suitable for long-distance connection scenarios.
  6. Debug and peripheral connection:
    • Use a USB-A to USB-C cable to connect your PC to the J7 debug interface on the adapter board
    • For USB peripheral expansion, connect devices to J5 on the adapter board
