WIFI / BT Antenna Interface ​
  • Wi-Fi: 802.11ax, 2.4G/5G bands, 2×2 MIMO
  • Bluetooth: BT 5.2
Hardware Connection ​
Install the antennas to the antenna interfaces of the Rhino Pi-A1. When using WIFI/BT functions, you need to install two antennas to enhance the transmit power and receive sensitivity of WIFI/BT.
You can refer to the Hardware Information tutorial to locate the corresponding hardware interface.
Recommended antenna: AIWF022 antenna
Using Bluetooth ​
For Bluetooth connection on the Rhino Pi-A1 integrated system, you only need to connect on the Android side. The connection method is as follows:
  • Open the Android home screen, click and drag the left mouse button upward on the screen, and find the Settings option on the page that appears.
Bluetooth Settings
  • Click Settings - Connected devices - Pair new device to scan and connect Bluetooth devices.
Bluetooth Scan
